Blue iris shutting down after about 30 seconds
Cleve
Mar 3, 2021
183
27
Alabama
I was having problems getting alert sounds to play on my BI computer and I read somewhere to uncheck run as local windows service. I knew better but I did it anyway, restarted the program and all cameras came back up with no signal, and the program would shut down after about 30sec. When I tried to go back and check run as windows service it wants a administrator log in which I have not used. Always ran as "Local Console". So I added another user and gave it administrative permission and created a new user name and password. It still will not let me changed anything says administrative credentials are wrong can't be blank (1326) Anyone know who to fix this?
I presume that the account you normally login to windows with is an administrative user, do you use a password or does it start up directly to the desktop, are you logging into windows with a PIN or a Microsoft account?
This is something I used awhile back, not sure if it applies to you problem or not:
If unable to sign into a service:
Local Security Policy (under windows administrative tools - windows tools in windows 11)
Local Policies
User Rights Assignment
Log on as a service
Right click -Properties
Add User or Group
