Sonnie IPCT+ Member Oct 31, 2022 355 172 Lower Alabama Aug 3, 2024 #1 Diagnosis of the camera via IP address direct access shows everything as normal, but BI shows the yellow triangle and signal loss, even though it is showing the image, albeit a very dark image.
wittaj IPCT Contributor Apr 28, 2019 30,862 59,226 USA Aug 3, 2024 #2 That one is an easy fix and we have to do it with cameras that are being used for LPR. Because the image is all black, BI thinks it lost signal. Go to the watchdog tab and uncheck the "interpret monocrome video as as a loss of signal" box. Reactions: duplo and JNDATHP
Sonnie IPCT+ Member Oct 31, 2022 355 172 Lower Alabama Aug 3, 2024 #3 Thank you! ... and thank goodness that was indeed an easy one. Bingo! Reactions: JNDATHP
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,225 Evansville, In. USA Aug 3, 2024 #4 You need to spend some quality time studying the Blue Iris help. Reactions: Sonnie
Sonnie IPCT+ Member Oct 31, 2022 355 172 Lower Alabama Aug 3, 2024 #5 looney2ns said: You need to spend some quality time studying the Blue Iris help. Click to expand... But then the forum wouldn't get as much traffic, right?
