Xepher:
So the
Blue Iris upgrade on 1 Feb of this year caused my GW cam to cease functioning... not having time to figure out what the issue was, I simply reverted back to an older version. Last month I played with it, and had some back and forth with the BI folks to figure it out. It turns out there is/was some issue with H264/265 decoding, and if I recall, 265 does not work. Well I didn't change anything in my camera... but it works now and the cam/BI is set to H.264. To do this you have to log in with a web browser. (I use IE). I'm not on this forum too often, but if you still have problems send me a note or do something to get my attention and I'll try to help. All in all, this camera works quite well for what I want it for, day, night, rain and snow. Although the "license plate" blocking shields work....
The drop down menu for adding a GW cam did not work for me.
Good luck,
Wayne
