- Jul 13, 2016
- 29
- 0
Ok, So I have 20 cameras, most are Speco 1920x1080, capable of 30fps (the other cameras are capable of the same as well).
The current computer I am using, I can't do more than 10fps on the cameras, and the cpu is spiked at 90%+ no matter what I do, and the cameras are set to record direct to disk, with the BI file format.
I want to record all cameras, 24x7... at at least 15fps (if not 20). I am looking at building an i7-4790K, with an Asus Motherboard, and 32G ram. The mobo has 8 sata (6 handled by the Z87 chipset, and raid capable, and the other 2 by asus something or other). Also, looking at adding more cameras later... or building another server
I was looking at the WD Purple drives, possibly the 8TB ones, but I need to figure out how much space the streams will take, and how much to keep for long term storage (looking for about 1 week worth of storage).
Should I use 1 drive for the OS, 1 for the "new", and then set up a raid array for "storage"? that would be a 6 drive array.
Would it be better off using an actual raid card? What kind of raid should I use?
Any help or suggestions would be appreciated
