Blue Iris run as a VM or Docker
ALias
Aug 31, 2025
4
Earth USA
I am consolidating servers and moving to virtualization and containers for the various services I run locally.
On the topic of Blue Iris I have some questions, any input would be greatly appreciated especially from those who have run from a VM or container (Docker, etc).
1. Can BI be run from a VM or container?
1a. If yes which would provide the best performance (equal or as close to bare metal)?
2. Server will be setup as Z490 main board, 64gb memory, 12gb NVDA GPU, 750watt PS, i10700K CPU, 8tb storage space ssd/hdd config, 256gb NVME for OS boot, a GPU yet to be spec'd for BI graphics processing, 4 port 1gbs Intel NIC. This spec has been verified as sufficient with some future proofing built in. Any suggestions to make it tighter/robust is welcomed.
3. Total number of cameras will be +/-10.
4. FYI, host system resources (cpu, memory, graphics, storage) will be configured in container/vm per requirements. BI will get a dedicated amount of resources to ensure consistent availability and performance. If you have any suggestions on min/max resource allocation please share.
Thank you in advance for your input.
