Forgot to mention you need to turn off "Use secure session keys and login page" in BI under Web Server Advanced for this to work.
I Just wanted to thank you for this post. I have an underwater camera in my koi pond that I wanted to use in IP Viewer on the Roku. I like the screensaver option. Would be nice to walk through the living room and see the fish doing their thing. The camera alone would not work with the IP Viewer. I had previously purchased the software, but hadn't taken the time to learn it. But this post was enough to get the koi cam working on the Roku app and that's all I wanted. So thank you!I have been using IP Camera Viewer Pro for the Roku.
Roku
It cost about $5.00.
You can test with the free version first it only let's you setup one camera.
See example on setup from one of my cameras. Once you setup one camera you just need to copy an existing camera give it a different description and change the camera Stream URL to point to the BI new camera short name.
I point to my Blue Iris IP and port not directly to the cameras. I couldn't get many of my cameras working in IP Camera Viewer but pointing to BI they all work.
You can even point to a camera group name and display the group of cameras.
You can also set it up so it is the Roku screensaver if you want to display your cameras.
Hope this is helpful.
Same. Would love to get an audio enabled RTSP stream on Roku but from what I’ve heard they don’t support thatThrowing in my 2 cents...
The screenshot was the key for me as I was having trouble getting BlueIris and the cam viewer on Roku to work together. Too bad it's only MJPEG though as I was hoping to get the audio too. Regardless it does work.
Disregard. Did some more research and found what I needed.Hello everyone. I feel foolish for asking this but what port should I be using when configuring? I have tried 8000 and 8033 with no success. TIA
Yes I am using the "IP Camera Viewer Pro" app. When I use my blue iris ip and port for the camera I see the video just no ptz. When I try to use the camera’s ip and port and ONVIF Auto config I get no video. The camera is a cheap lightbulb camera branded Eversecu B2-R-B. The ptz works in blue iris with this cam.What app on the Roku?
What make and model of PTZ?
if the PTZ is ONVIF-compliant perhaps the app has a selection like "ONVIF Auto Config" as does the "IP Camera Viewer Pro" app in post #2.
