Hello All
Would BI be able to work ok without massively straining the CPU on a computer with the following specs?
Operating system
Windows 10 Home (x86-64)
Processor -Intel Atom x5-Z8350
RAM - 4GB DDR3
Graphic type -Intel HD Graphics 400
4K Support - 3840 x 2160p @ 30Hz
USB -1x 2.0, 1x 3.0
Internal storage - 32GB / 64GB eMMC flash
Expansion options - Micro SDXC slot
I would use a 128 SD card to boost storage.
I would be using 1 camera at 20-30 fps and low resolution (480x640)
Thank you
How do I delete this?? Found a helpful article from another user after posting
Operating system
RAM - 4GB DDR3
USB -1x 2.0, 1x 3.0
Thank you
