Try continuously pinging the camera. If you get big latency spikes or packet loss that would indicate a network issue. This is a good tool to do this and get immediate visual results: bp2008/pingtracer
1.Sd card footage is perfect, so not power supply..doubt its the cable
Thank you will try tonight and report backTry continuously pinging the camera. If you get big latency spikes or packet loss that would indicate a network issue. This is a good tool to do this and get immediate visual results: bp2008/pingtracer
Im Im getting this same is freeze.. i have a netgear gigabit switch which is like 2 months old.. everything was working great.. now getting this freezing between 5 to 10 secs only during auto tracking moments .Fenderman - no it is a dahua.
Cainrand - I don't think I'm out of resources. Cpu is steady around 23% and system has 8 GB RAM. I'm going to fire up resource mon and see if maybe there is some disk queuing going on. Disabling a/v entirely is also something I'll try tonight.
Maybe i should restart the switch.. power on and off. Wonder if that would help.. im also gonna test it with the router off and only using the switch tonight toodoubt its the cable
Good god.. after my relentlessness, i set the receive buffer to 10mb and its seems to have corrected the problem... Ill post back if the problem occurs againdoubt its the cable
That wouldn't explain why it only occurs during movement and why the NVR has the same problem...Good god.. after my relentlessness, i set the receive buffer to 10mb and its seems to have corrected the problem... Ill post back if the problem occurs again
I also turned the microphone khz down too.. no clue. Ive been trying anything and everythingThat wouldn't explain why it only occurs during movement and why the NVR has the same problem...
The camera?Have you tried setting it back to factory defaults?
