Today at 2:01 AM EST Blue Iris decided to completely wipe out all recordings that weren't locked. Frustration aside, I would like to figure out why this happened to prevent it from happening again.
Blue Iris config has not been changed for over 6 months, while the last camera change was about 30 days ago. It's been humming along just fine, deleting old recordings as the drive fills up just fine.
My clip/archive settings are as follows:
New: 100GB very fast drive, moves to "Stored" after 1 day or 65GB used.
Stored: 6TB drive, deletes after 3800GB used or 999 days.
Alerts: same 6TB drive, deletes after 300GB / 999 days.
Archive: same 6TB drive, deletes after 1500GB / no day limit.
RAM_Disk: 1GB RAM drive, used for home automation purposes. Deletes after 1GB / 1 hour.
The Blue Iris version is rather old, 5.5.7.1 (5/14/22), but never had any issues with it.
Here's the relevant log entry where it decided to delete everything:
Full log for this time range:
Blue Iris is configured to do DB maintenance at 2AM every day. In addition, on Wednesdays (the day this occurred), all cameras are set to reboot at 2AM.
The only odd thing I've noticed is the Clip Storage dialog is now showing duplicated storage bar graphs for both drives. I'm thinking this may be the root cause.. it saw used space was way over max as it is now duplicated?
Since this occurred I've completely restarted the Blue Iris machine, and the Clip Storage dialog still shows duplicated bar graphs (see screenshot).
Anyone have any insight as to what the heck happened!?
Code:
0 6/14/2023 2:01:29.372 AM Stored Delete: 1991 items 3.60T [8462/23976 hrs, 7.47T/3.71T, 895.4G free] 84 locked
0 6/14/2023 2:02:28.657 AM Archive Delete: 7424 items 1.08T [2.55T/1.46T, 4.47T free]
Code:
0 6/14/2023 2:00:03.020 AM Clips DBCompact: started
1 6/14/2023 2:00:30.911 AM Cam6slowdown Signal: network retry
1 6/14/2023 2:00:33.782 AM Cam4 Signal: network retry
1 6/14/2023 2:00:34.230 AM Cam6 Signal: network retry
1 6/14/2023 2:00:34.472 AM Cam4s3 Signal: network retry
1 6/14/2023 2:00:35.152 AM Cam6s3 Signal: network retry
1 6/14/2023 2:00:40.182 AM Cam5 Signal: network retry
1 6/14/2023 2:00:40.847 AM Cam6slowdown Signal: network retry
1 6/14/2023 2:00:40.976 AM Cam5s3 Signal: network retry
1 6/14/2023 2:00:43.888 AM Cam4 Signal: network retry
1 6/14/2023 2:00:44.374 AM Cam6 Signal: network retry
1 6/14/2023 2:00:44.432 AM Cam4 Signal: Failed to connect
1 6/14/2023 2:00:44.619 AM Cam4s3 Signal: network retry
1 6/14/2023 2:00:45.096 AM Cam6 Signal: Failed to connect
1 6/14/2023 2:00:45.122 AM Cam6s3 Signal: network retry
1 6/14/2023 2:00:45.253 AM Cam4s3 Signal: Failed to connect
1 6/14/2023 2:00:45.920 AM Cam6s3 Signal: Failed to connect
1 6/14/2023 2:00:46.941 AM Cam4 Signal: Failed to connect
1 6/14/2023 2:00:47.604 AM Cam6 Signal: Failed to connect
1 6/14/2023 2:00:47.968 AM Cam4s3 Signal: Failed to connect
1 6/14/2023 2:00:48.630 AM Cam6s3 Signal: Failed to connect
1 6/14/2023 2:00:50.201 AM Cam5 Signal: network retry
1 6/14/2023 2:00:50.764 AM Cam5 Signal: Failed to connect
1 6/14/2023 2:00:51.019 AM Cam5s3 Signal: network retry
1 6/14/2023 2:00:51.939 AM Cam5s3 Signal: Failed to connect
1 6/14/2023 2:00:53.271 AM Cam5 Signal: Failed to connect
1 6/14/2023 2:00:53.923 AM Cam6slowdown Signal: Failed to connect
1 6/14/2023 2:00:54.647 AM Cam5s3 Signal: Failed to connect
0 6/14/2023 2:00:55.077 AM Clips DBCompact: finished
3 6/14/2023 2:00:55.906 AM Cam6slowdown WATCHDOG
1 6/14/2023 2:00:56.107 AM Cam6slowdown Signal: network retry
0 6/14/2023 2:00:56.867 AM Cam6slowdown Email: Elkon <[email protected]> with 0 attachment/s
1 6/14/2023 2:00:57.597 AM Cam6slowdown Signal: Failed to connect
3 6/14/2023 2:00:58.912 AM Cam4 WATCHDOG
1 6/14/2023 2:00:59.113 AM Cam4 Signal: network retry
0 6/14/2023 2:00:59.296 AM Cam4 Email: Elkon <[email protected]> with 1 attachment/s
3 6/14/2023 2:00:59.397 AM Cam6 WATCHDOG
1 6/14/2023 2:00:59.599 AM Cam6 Signal: network retry
0 6/14/2023 2:00:59.647 AM Cam6 Email: Elkon <[email protected]> with 1 attachment/s
3 6/14/2023 2:00:59.822 AM Cam4s3 WATCHDOG
1 6/14/2023 2:00:59.823 AM Cam4s3 Signal: network retry
0 6/14/2023 2:01:00.090 AM Cam4s3 Email: Elkon <[email protected]> with 1 attachment/s
1 6/14/2023 2:01:00.306 AM Cam6slowdown Signal: Failed to connect
3 6/14/2023 2:01:00.328 AM Cam6s3 WATCHDOG
1 6/14/2023 2:01:00.329 AM Cam6s3 Signal: network retry
0 6/14/2023 2:01:00.566 AM Cam6s3 Email: Elkon <[email protected]> with 1 attachment/s
1 6/14/2023 2:01:01.466 AM Cam2s3 Signal: network retry
1 6/14/2023 2:01:01.694 AM Cam2 Signal: network retry
4 6/14/2023 2:01:02.170 AM Cam6 Signal: restored
4 6/14/2023 2:01:02.187 AM Cam4n Signal: restored
4 6/14/2023 2:01:02.193 AM Cam4 Signal: restored
4 6/14/2023 2:01:02.364 AM Cam4s3 Signal: restored
0 6/14/2023 2:01:02.428 AM Cam6 Email: Elkon <[email protected]> with 1 attachment/s
0 6/14/2023 2:01:02.597 AM Cam4 Email: Elkon <[email protected]> with 1 attachment/s
0 6/14/2023 2:01:02.754 AM Cam4s3 Email: Elkon <[email protected]> with 1 attachment/s
4 6/14/2023 2:01:03.056 AM Cam6s3 Signal: restored
0 6/14/2023 2:01:03.196 AM Cam6s3 Email: Elkon <[email protected]> with 1 attachment/s
1 6/14/2023 2:01:04.383 AM Cam3s3 Signal: network retry
1 6/14/2023 2:01:04.739 AM Cam3 Signal: network retry
3 6/14/2023 2:01:05.207 AM Cam5 WATCHDOG
1 6/14/2023 2:01:05.407 AM Cam5 Signal: network retry
0 6/14/2023 2:01:05.473 AM Cam5 Email: Elkon <[email protected]> with 1 attachment/s
1 6/14/2023 2:01:06.167 AM Cam6slowdown Signal: network retry
3 6/14/2023 2:01:06.186 AM Cam5s3 WATCHDOG
1 6/14/2023 2:01:06.190 AM Cam5s3 Signal: network retry
0 6/14/2023 2:01:06.386 AM Cam5s3 Email: Elkon <[email protected]> with 1 attachment/s
4 6/14/2023 2:01:08.134 AM Cam5n Signal: restored
4 6/14/2023 2:01:08.189 AM Cam5 Signal: restored
0 6/14/2023 2:01:08.451 AM Cam5 Email: Elkon <[email protected]> with 1 attachment/s
4 6/14/2023 2:01:08.652 AM Cam5s3 Signal: restored
4 6/14/2023 2:01:08.729 AM Cam6slowdown Signal: restored
0 6/14/2023 2:01:08.795 AM Cam5s3 Email: Elkon <[email protected]> with 1 attachment/s
2 6/14/2023 2:01:09.843 AM Cam4s3 AddToBIDB failed 1
0 6/14/2023 2:01:09.893 AM Cam6slowdown Email: Elkon <[email protected]> with 1 attachment/s
2 6/14/2023 2:01:10.030 AM Cam4 AddToBIDB failed 1
2 6/14/2023 2:01:10.350 AM Cam6s3 AddToBIDB failed 1
2 6/14/2023 2:01:10.595 AM Cam6 AddToBIDB failed 1
0 6/14/2023 2:01:10.787 AM New Move: 38 items 55.3G [18/24 hrs, 122.1G/65.0G, 40.5G free] 17 locked
1 6/14/2023 2:01:11.528 AM Cam2s3 Signal: network retry
1 6/14/2023 2:01:11.820 AM Cam2 Signal: network retry
1 6/14/2023 2:01:12.301 AM Cam2s3 Signal: Failed to connect
1 6/14/2023 2:01:12.458 AM Cam2 Signal: Failed to connect
1 6/14/2023 2:01:14.214 AM Cam3s3 Signal: network retry
1 6/14/2023 2:01:14.810 AM Cam3 Signal: network retry
1 6/14/2023 2:01:14.965 AM Cam2 Signal: Failed to connect
1 6/14/2023 2:01:15.029 AM Cam2s3 Signal: Failed to connect
1 6/14/2023 2:01:15.301 AM Cam3s3 Signal: Failed to connect
1 6/14/2023 2:01:15.481 AM Cam3 Signal: Failed to connect
1 6/14/2023 2:01:17.989 AM Cam3 Signal: Failed to connect
1 6/14/2023 2:01:18.010 AM Cam3s3 Signal: Failed to connect
3 6/14/2023 2:01:26.692 AM Cam2s3 WATCHDOG
1 6/14/2023 2:01:26.693 AM Cam2s3 Signal: network retry
0 6/14/2023 2:01:26.802 AM Cam2s3 Email: Elkon <[email protected]> with 1 attachment/s
3 6/14/2023 2:01:26.906 AM Cam2 WATCHDOG
1 6/14/2023 2:01:27.107 AM Cam2 Signal: network retry
0 6/14/2023 2:01:27.156 AM Cam2 Email: Elkon <[email protected]> with 1 attachment/s
4 6/14/2023 2:01:29.080 AM Cam2s3 Signal: restored
0 6/14/2023 2:01:29.313 AM Cam2s3 Email: Elkon <[email protected]> with 1 attachment/s
0 6/14/2023 2:01:29.377 AM Alerts Delete: nothing to do [7357/23976 hrs, 46.8G/300.0G, 4.47T free] 34 locked
0 6/14/2023 2:01:29.708 AM Cam3s3 Email: Elkon <[email protected]> with 1 attachment/s
1 6/14/2023 2:01:29.768 AM Cam3s3 Signal: network retry
3 6/14/2023 2:01:29.778 AM Cam3s3 WATCHDOG
3 6/14/2023 2:01:29.808 AM Cam3 WATCHDOG
1 6/14/2023 2:01:30.009 AM Cam3 Signal: network retry
4 6/14/2023 2:01:30.160 AM Cam2 Signal: restored
0 6/14/2023 2:01:30.234 AM Cam3 Email: Elkon <[email protected]> with 1 attachment/s
0 6/14/2023 2:01:30.421 AM Cam2 Email: Elkon <[email protected]> with 1 attachment/s
4 6/14/2023 2:01:32.501 AM Cam3s3 Signal: restored
0 6/14/2023 2:01:32.623 AM Cam3s3 Email: Elkon <[email protected]> with 1 attachment/s
4 6/14/2023 2:01:34.156 AM Cam3 Signal: restored
0 6/14/2023 2:01:34.412 AM Cam3 Email: Elkon <[email protected]> with 1 attachment/s
3 6/14/2023 2:01:37.706 AM Cam1n MOTION_ABCG
0 6/14/2023 2:02:28.661 AM Timelapse Delete: nothing to do [29.3G/300.0G, 5.56T free]
1 6/14/2023 2:02:29.676 AM Clips MoveFile Error 32: N:\New\Cam1n.20230614_010047.bvr
1 6/14/2023 2:02:31.662 AM Clips MoveFile Error 32: N:\New\Cam5.20230614_000000.bvr
1 6/14/2023 2:02:33.721 AM Clips MoveFile Error 32: N:\New\Cam3.20230614_000000.bvr
1 6/14/2023 2:02:36.059 AM Clips MoveFile Error 32: N:\New\Cam2.20230614_000000.bvr
3 6/14/2023 2:10:24.906 AM Cam1n MOTION_ABCG
3 6/14/2023 2:18:37.200 AM Cam1n MOTION_ABCG
