- Apr 2, 2017
- 9
- 3
Alright so I'm looking to move away from zoneminder as it can't clear the disk as fast as it can fill it due to the millions of frames being separate files.
Blueiris seemed pretty highly recommended so I have the demo and am trying it out. So far I like it, but I'm trying to get ptz working with no luck.
I have cheap chinese ptz cameras (spare me the lecture) which work great with zoneminder and most other things.
The ptz function is controlled via onvif over port 5000. I set up BlueIris with the following:
https://img.superunicorn.net/i/tygvju.png
Custom port set to 5000 as is needed. That didnt work, so I tried other camera presets that are similar to the one I got like Sricam which mine is a clone of and whatnot. Still wouldnt work.
Curious I installed wireshark and filtered for port 5000, and found that there are no packets even being sent to that by blueiris. To rule anything else out, I installed another client that DOES work (happytime onvif client) and it shows packets on port 5000 just fine so I know wireshark is working.
So I thought well maybe the IP in the custom box is breaking it, so I left it as just 5000 and :5000 but had similar problems.
The custom port box on that just seems to not do anything as far as I can tell. Am I missing something really obvious here or what?
Here is wireshark using BlueIris: https://img.superunicorn.net/i/rpeybj.png
And here is wireshark using the other program that works to show that the capture is working: https://img.superunicorn.net/i/qqxzfk.png
