D dannieboiz Getting the hang of it May 13, 2015 498 72 Mar 22, 2020 #1 Anyone knows how to properly setup PIA split tunneling to work with Blue iris?
D dannieboiz Getting the hang of it May 13, 2015 498 72 Mar 22, 2020 #3 everying on the system behind the VPN except blue iris so i can remotely view the feeds.
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,225 15,128 USA Mar 22, 2020 #4 PIA should not affect your ability to remote view in any way, no matter how you set it up.
D dannieboiz Getting the hang of it May 13, 2015 498 72 Mar 22, 2020 #5 stepping back a little bit, I realized that my duckdns client is on the same PC. had to exclude that or move it to a new PC. thanks for the wakeup call!
