Blue Iris power consumption experiments
bp2008
Staff member
Mar 10, 2014
13,385
15,395
USA
I have my Blue Iris server connected to an Ubiquiti mFi mPower Pro now, which measures power consumption, so I ran some tests.
System #1
i7-3770K (stock speed)
16 GB RAM
1x SSD
4x HDD
Nvidia GTX 950 GPU (only to facilitate 4K@60hz output)
Blue Iris load of 635 MP/s, motion detecting
It is a bit of a power hog since it is years old, has so many HDDs, and a discrete GPU
Baseline Reading
82 watts @ 1% CPU usage (task manager) with Blue Iris not running at all.
Hardware Acceleration Enabled
132 watts @ 33% total CPU usage with Blue Iris GUI closed.
155 watts @ 55% total CPU usage with Blue Iris GUI open, maximized at 4K resolution, 6 FPS live view limit.
Hardware Acceleration Disabled
158 watts @ 77% total CPU usage with Blue Iris GUI closed.
167 watts @ 100% total CPU usage with Blue Iris GUI open, maximized at 4K resolution, 6 FPS preview limit. The system froze up and I had to unplug the network cord before even the mouse pointer would respond again.
System #2
16 GB RAM
2x SSD
3x HDD
Onboard graphics only
Blue Iris load of 350 MP/s, continuous recording without motion detection
I will not be measuring with the GUI open because this system never gets monitored live, and I have the live view frame rate limit set to 1 FPS. This is a small, nearly inconsequential additional load of about 2% CPU / 2 watts.
Baseline Reading
60 watts @ 1% CPU usage (task manager) with Blue Iris not running at all.
83 watts @ 15% total CPU usage with Blue Iris GUI closed.
97 watts @ 35% total CPU usage with Blue Iris GUI closed.
So basically, enabling Hardware Acceleration is helping to reduce the power consumption. That's good.
System #1
Saving about $12/year
((26*24*365)/1000)*0.05=$11.38
System #2
Saving about $6/year.
((14*24*365)/1000)*0.05=$6.13
Use your own electrical rate.
System #1
System #2
No one pays 5 cents a kwh... more like 11-25...
You are right for residential, although many rural power cooperatives in my area offer an "all electrical heat" subsidized rate that gets down there. I had my employers raw industrial rate without demand charges in my head (4.7 cents/kwh). It looks like the residential rates are anywhere from $0.07 to $0.27 / kwh.
If you live in Hawaii we are talking about:
System 1 - $61
System 2 - $33
Looks like about a few date nights worth of savings. Bonus!
It would be interesting to see numbers with a newer processor. Maybe I will go borrow one of those power meters...
One thing you can say about Oklahoma, it is a cheap place to live..... $0.04 per kwh
its cant be .04....you need to consider the price of electric, delivery and tax...a quick google search indicates 8-9c...
