<SOLVED>
Steps I took that fixed my problem, most likely the 3rd bullet that actually fixed it though.
I didn't want to hijack the other threads so started my own. I have read all other of these threads on this msg board and others.. have tried clicking things on and off, hardware acceleration, adjusting the fps/iframe, etc., and I'm still getting these 7 second freezes on playback. I'm at a loss at what I have missed (I bet you it's something completely simple). My Blue Iris app is allowed through Windows Firewall, all folders regarding Blue Iris are excluded in Windows Defender. Any help would greatly be appreciated!! Thank you!
Video System Info:
i5-4590, 3.3ghz
4gb ram
windows 10 pro
Connection is: Router > POE Switch > Camera
Example video and settings images below:
- Made sure I actually went to the Intel HD 4600 website to get the latest graphics driver and installed instead of the intel driver update utility as that one kept saying I had the latest driver. That might've affected the Hardware Decoding option because of an old driver
- Deleted camera and added it back in
- Change my computer power options in control panel > advanced power settings > Changed "Turn off hard disk after 20 minutes" to "Never" - This is probably the setting that actually did the true fixing
Video System Info:
i5-4590, 3.3ghz
4gb ram
windows 10 pro
