F freqflyer Young grasshopper Dec 2, 2015 49 3 Apr 29, 2016 #1 Does blue Iris have any outputs that it can trigger? Example. It senses motion on a camera and turns on recording or a notification. Can it also send a signal out to trip a relay that would turn on external IR lights?
R riceandbeans Getting the hang of it Nov 1, 2015 80 42 Austin, TX Apr 29, 2016 #2 Yes. This should be explained in the BI docs.
F freqflyer Young grasshopper Dec 2, 2015 49 3 Apr 29, 2016 #3 Where can I get the BI docs? I download the trial of BI and i found the help in it but not a doc file.
fenderman Staff member Mar 9, 2014 36,891 21,409 Apr 29, 2016 #4 freqflyer said: Where can I get the BI docs? I download the trial of BI and i found the help in it but not a doc file. Click to expand... Rice means the help file...see the alert tab in the camera properties. To trigger a relay see the section on sealevel devices.
D devastator Getting the hang of it May 22, 2015 169 28 Belgium May 2, 2016 #5 And you can also trigger the pins on an arduino, I believe
M Mattias Young grasshopper Nov 1, 2015 35 8 May 2, 2016 #6 The Arduino will be the cheapest way, there are som threads in the forum about this for example these: https://www.ipcamtalk.com/showthread.php/8556-Blue-Iris-Serial-to-from-Arduino-(Inputs-and-Outputs) https://www.ipcamtalk.com/showthread.php/3359-ARDUINO-amp-BLUE-IRIS-SERIAL-digital-i-o-DIO
