Hi all.
I have a blue iris on a Proxmox windows 10 vm with 20+ cameras.
In the past few months it is not behaving well. Occasionally, it somehow forgets to put the video files in "New" folder in its own database and I come up with nothing for a few days when I look back in the timeline or calendar.
The files are already there, but somehow BI thinks they don't belong to it! As a consequence, the drive grows and BI goes mad about the drive usage (it shows a lot of "other files" in grey). As a solution I have to rebuild the database and it's all fine again until it happens again.
Last time, I thought maybe it's some permission issue or something which BI cannot delete or move the files from drive to drive, but no things were good.
Anyway, I even formatted my SSD and rebuilt the database, still the issue is there... Yesterday I rebuild the database and now it's fine.
Any help would be appreciated.
Spec:
Windows 10 under Proxmox vm.
CPU i7-6850K, 4 cores passthrough to vm
RAM 128GB, 16GB passthrough to vm
Main OS drive is 64GB (drive C)
one SSD 1TB is directly passthrough to the vm (Drive G)
one HDD 8TB is directly passthrough to the vm (drive H)
Blue Iris is v5.7.9.4
The machine is fully disconnected from the internet and lives in a seperate VLAN with cameras.
Directory management in BI:
DB is on drive G (1TB SSD).
NEW is on drive G (1TB SSD), Limit Size is 500GB, Move to folder STORED
Alerts is on drive G (1TB SSD), Limit Size is 50GB, Limit clip age 30days, Delete
STORED is on drive H (8TB HDD), Limit Size is 7000GB, Delete
AUX1 -> not used
AUX2 (which is H:\BlueIris\faces) on drive H (8TB HDD), Limit Size 1 GB, Limit clip age 70days, Delete
The rest of AUX 3,4, ... are unused
The windows vm is not being used for anything else - just BI. There is no other files on drive G (1TB SSD). Only less than 1GB other files on drive H (8GB HDD).
Spec:
AUX1 -> not used
