Hi thanks for your help, there is a screenshot(2) of the configure box in my earlier postOne more click need to the configure box, then a screen shot.
no just used the make of camera etcSorry, didn't expect the file attachment and never looked at it. DUHHHHH
Did you get those settings by using "find inspect"?
cheers for trying to help channel 0 didnt workDid you try streaming/Channel/0 by chance? as the mainstream?
how do i use these settings?Try using find and inspect. Use those settings instead and see what happens.
have i got the settings right?if i have then there is no changeTry using find and inspect. Use those settings instead and see what happens.
Cheers for your help, I will try this tomorrow, getting late hereYes, just click OK and see if your get main stream triggering on motion. Worst case you already have a screen cap of the old settings you can default back to.
Still not workingCheers for your help, I will try this tomorrow, getting late here
thanks for your help,started working on its own,go figureWhen live viewing the cam in BI if you double click the cam do you see the video change from the substream to the main stream? You should be able to see a slight flicker as it changes from one to the other?
