- Jun 30, 2014
- 232
- 540
System Model: HP Compaq Elite 8300 CMT
Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 16G
Operating System: Windows 10 Pro 64-bit (10.0, Build 19043)
Hi folks - I'm running BI on a dedicated machine (specs above). It is used only for BI (no other foreground interactive use or background non-essential apps).
I have 11 cameras controlled by BI, 2 of them are 8k, the others are 5k, all using Direct to Disk recording to a SSD.
I've been using this machine with the same camera configuration for a couple of years now; when I first started CPU would hover around 60-70%. It has crept up over time though, and now CPU usage is 95-100%. RAM is only half used.
Tried limiting the FPS on all of the cameras but that had no effect on CPU usage.
I presume the increase in CPU required is coming from Windows 10 and BI updates. Task manager shows BI using 95-100% CPU.
Does anyone know of any BI customization that I can try to reduce CPU demand?
Thanks for any help!
Memory: 16G
