Have 2 x IPC-HDW5231R-Z and Blue Iris v4.7.6.7
I have IVS Tripwire setup with the cameras Motion Detection disabled, also using the cameras 'admin' credentials, with BI's config I have PullPointSubscription ticked, "Cameras digital input or motion" ticked, and all is well,
The Problem:
if i restart windows or edit BI's camera settings, it will revert settings i've set on the IPC-HDW5231R-Z admin page.
One setting that seems to always come back is "Motion Detection", even though I just want IVS>Tripwire, a temp fix for the moment is to set Threshold/Sensitivity where "Motion Detection" would not occur, this same problem used to occur when i had a Synology NAS, it always seemed to revert the iframe to 30, even though i set it to 15, Synology had a update to prevent this "Keep Camera Settings.
The Problem:
said:
