- Mar 9, 2014
- 36,883
- 21,419
From the whats new section of the Blueirissoftware.com website
"We have moved away from using InstallShield as our installation software provider in favor of Advanced Installer. Resulting new considerations and caveats: (1) Running the new installer on a PC which previously used InstallShield may result in a duplicate entry in the Windows Installation Database–you should first uninstall the old version if you are completing a repair or reinstallation. (2) There is no longer a choice between 32 and 64-bit, this is now done automatically. If you must run Blue Iris 32-bit on your 64-bit system, this may now require a manual installation of the 32-bit update from the website."
