Trying to resolve issue where I am not receiving MMS messages when Motion is detected.
I've narrowed the issue down to using an iphone on the AT&T network, Although I'm not sure if it's isolated to Where I'm Located (South Florida).
If I change the notification address in Blue Iris from <My [email protected]> (for picture w/ text mms) to <MY [email protected] (Text only SMS) I receive the text (text only no Pic) from Blue iris that movement has been detected.
When set to MMS, usually I will get a picture notification 18 - 24 hours after the event.
I've tried 2 different iphones (5s & 8 plus) Running Most current IOS available dependent on the phone. I have tried all setting on the iPhones (iMessage on & off, Wifi on-off, MMS enabled, resets etc.). MMS requires Group messaging on & minimum 3g Network and that is not an issue with my iPhones.
I have tested on Android and there is no issue and MMS messages from Blue Iris are received within a few seconds. The Android phone tested on is a family member living in North Fla. on my AT&T plan using the AT&T network.
Anyone have similar issue OR hopefully someone has solved the issue in the past (Outside of ditching the iPhone) would appreciate some feed back.
