- Mar 27, 2018
- 7
- 0
I posted this before but I knew a lot less then. Posting back with more info
Supermicro X8DTL-I LGA1366 Dual Xeon E5645 6-Cores CPU 16GB DDR3 ATX Motherboard
Dell PowerConnect 3548P Managed Network Switch
Support data:
Version: Release 4.7.2.2 x64
Service: Yes
License: xxxxxxxxxxxxxxxxxxxxxxxxxxxx
Name:
Email:
Support: Basic
Expires: 10/30/2018 5:31:59 PM
WAN: http: 66.194.4xxxxxxxx
OS: Windows 10 Pro
CPU: Intel(R) Xeon(R) CPU E5645 @ 2.40GHz [51%]
RAM: 3.26G
Clips: 14 files, 11.3G/31.0G
Storage: !! E: +2.78T, C: -14.0G
9 x 4MP Qsee IP cams - Hardwired with Cat6
All cameras connect to the network switch.
BI box connects to the same network switch.
CPU usually hover around 40%
Ram around 3gb of 16gb
When I start BI I compare the time difference between the camera and gui. It is about 1 sec. This slowly increase to about 70 seconds if I leave BI running for about 30 minutes.
After the initial 30 minutes. The lag does not increase anymore even after running for some days.
I have tried another network switch.
I have tried both nic of this board and also an external usb nic
Support data:
Service: Yes
Name:
Email:
Support: Basic
OS: Windows 10 Pro
RAM: 3.26G
