I created a Blue Iris Help Chatbot using the current Blue Iris help pdf file. The link to the Chatbot is below, let me know what you think of it, is it helpful.
Blue Iris AI Help Chatbot
What was the problem you needed help with.I just used to help with a problem which it failed to do, but its a brilliant idea. will be useing it again.
I did think it was a long shot but was getting desperate, I'm not very good with the tecnical side of networks and networking...Unfortunately a chat bot will be of very limited use for issues that are not answered clearly in the help file or in the LLM's original training data.
Thanks, I have exempted the BlueIris folder and both BlueIris folders on my two hard drives that recordings are saved to. to get the Licence update to work i had to dissable the Acronis Agent in the services, then on rebooting the machine it started it again. all good and working fine on the latest version release.Acronis agent has a type of malware/antivirus component to it.
Hopefully you can exempt BlueIrise.exe or other Blue Iris executables from scanning for best performance.
