I have a few BI systems that I've setup in the past so I'm very familiar with the software and getting pretty good configuring I got a new job and my boss wants me to setup a very nice system for security. I'd like some real high resolution cams(advice on what is actually the quality cutoff as far as megapixels) I'm thinking at least 20 cams. Im going to have it behind its own router with cat 6 cable. I'd like to know best practice to make sure the system won't lag and how to calculate correctly. I looked at the wiki and didn't see i9 listed is there a reason for this? And if so which i7 would be best? I found a 14 TB wd purple drive and would like to know if its better to just use one or add a couple and spread the cameras over two of them......Just want smooth video. I know my other systems I set fps to 15 and they seem to do well just not sure how the system will react to 20 higher rez cams. Hes allowing me to spend some money but I still would like to keep it in a realistic amount and not just spend to spend. Any help will be appreciated. I've learned everything from here this will be the best system build yet so pretty excited. OH And how much ram should I be looking at? Added a pic of the pc I was looking at. And any recommendation on cameras if anyone has good suggestions,
As far as battery backup I've been using the APC 1500VA model and they work great but was also thinking of getting a bigger one for this system and making sure all switches are on backup power as well. Am I forgetting anything?/ I'm looking at the four routers for this system. Anyone using any of these models? Just looking to see what you guys think while Im researching and planning. Let the fun begin.
