I've noted this a few times, and I think I have narrowed it down to when clips are deleting
If I clear a bunch of space, and then let Blue Iris go, its ALWAYS fast, no hangups or anything. But the moment it hits the point where it needs to delete clips, it will sometimes hang up a little bit. This always happens when a new motion clip starts, I'll click the active camera in UI3 and it will just hang there
Eventually it will fix itself, and the clip is full, and intact
Has anyone else had this issue? I can re-create it perfectly by just clearing space myself, and then for the next X hours, there is no problem
One thing that maybe could be an issue is that I'm running ReFS. Perhaps I'll switch to NTFS and see if the issue is still present
