Hello
I am looking to replace our current 64 channel Hikvision DS-9664NI with a Blue Iris system possibly.
Searching through video and feeds staying connected with the Hik nvr are getting a bit clunky. Plus the recorder is beginning to randomly reboot.
Would it be possible for a Blue Iris system to support around 55 or so HD video feeds on one machine and be able to retain footage for a decent amount of time?
Here would be the specs required since I would like them to match or at least be a small upgrade to our current system.
The second concern would be video retention. We want to have video stored for a pretty long duration I would even consider dropping it to a 3-month minimum. How would I be able to repurpose the drives on a new desktop PC? I am assuming an i9 box would be required (hello to a big electric bill).
I did look into Exacq vision, however don't like the idea of a recurring license fee and per camera license. Would consider other VMS systems if they had a per channel fee, Salient Systems is out of the picture.
- Ability to support 55 5MP video streams at 8 FPS
- Ability to store at minimum 6 months of video footage
- Ability to "tag" or differentiate between videos where motion is occurring for quicker video playback or investigation.
- Ability to support Hikvision, Bosch, Honeywell, and Axis IP Cameras
- Ability to support ONVIF video cameras
- Ability for remote playback and remote live view
- Motion event detection takes place on the recorder
