Blue Iris does not find my new B5442E-Z4E
Dave Lonsdale
Pulling my weight
Dec 3, 2015
460
195
Congleton Edge, UK
Having entered the correct IP address for my new B5442E-Z4E from Andy (Dahua HFW5442E-Z4E), although I can get video using Dahua RTSP, BI does not recognise this camera (suggests foscam) and so, for example, does not correctly read the sub stream (unlike all my other Dahuas). Nor is it in the list of connected cameras if I blank the address. It appears to me that ONVIF is on if that makes any difference. Would a knowledgeable person, eg fenderman, please advise...
Here is what BI used for mine when I did Find/inspect. But I have the substream unchecked in the cam GUI.
This is the whole string for the Main stream entry: /cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
Here is the Video settings from the cam GUI.
Also, if you changed the account password since you did the first password, it may have not changed the Onvif User password. I have seen this happen for another user. Under system/account/ the Onvif user tab, make sure the password is what you expect.
Thanks again for your support samplenhold. Unfortunately, the ONVIF password had been updated automatically. When I blank the address in BI and do a camera discovery, this one is not in the list - doesn’t need any password. ONVIF definitely still not working. Unless you have any other ideas, I will now take the camera down and do the factory reset button.
In most cases whatever BI finds in the find/inspect will work regardless of the brand. Only one of my Dahua is actually using Dahua in the camera setting in BI.
I would suggest still going to the ONVIF and changing the password to match what you want it to be - these things do quirky things sometimes.
Very few of my cameras show up in the blank the address camera discovery, so I think it is a user/pw issue.
If all you are missing is the substream pull, that is simple to fix - you just copy the main stream parameters and paste it in substream and change the number.
If none of that works, you can always try the factory reset from the GUI first before pulling it down.
If I read correctly, BI sees the camera, but you do not like that is says Foscam instead of Dahua and the substream isn't showing?
If so, screenshot the add camera screen and we can help you get the substream.
Oh the dreaded / main stream.
You said you still get video if you use Dahua RTSP? If so, screenshot that setup.
This will still work:
Add in front of channel in substream:
/cam/realmonitor?
So it should be:
/cam/realmonitor?channel={CAMNO}&subtype=1&authbasic={AUTH64}
Every Dahua is a little different I have seen - mine are all over the place in the BI settings.
You are welcome.
You should have zero issues without ONVIF. The only reason you would need that is if you are pulling IVS triggers over from the camera into BI. If you are using BI motion detection, then you are all good!
