Blue Iris - Disable a camera at certain times on certain days - if a certain profile is active
Rfpower666
Oct 11, 2022
4
6
Norway
As the title states;
I have blue iris setup as follows:
2 schedules; Home and away - which are triggered by geofence. Works great.
When at home, one of my cameras is disabled when the home profile is activated - this works great
I have an another camera though I can't quite figure out how to get to do what I want...
Heres the situation:
When profile "home" is active AND it is friday or saturday - I want one camera to stop recording and go disabled between 4pm and midnight.. How may i achieve this?
? like that...?
Reactions: Cameraguy
You make one of the profiles to be for the time you don't want it active and then you uncheck the continue to display and stream video while inactive if you don't want it showing. Then make sure in recording you have that profile set to not record.
Sorry for the late reply - Finally got around to looking at this again - Not sure i understand. When the profile "home" is active AND it is friday night between 6pm and 8pm say - i want this one camera do be disabled.. However if the profile "Away" is active i do not want it to be disabled..
If i select the override global schedule - it won't change profiles like the other cameras when i come or go..?
Normally in "away" profile - push notifications are active - in "home" profile - everything is the same as in "away" profile, except push notifications are disabled.. I still want this to be the normal behaviour - But if in "home" profile AND Friday between certain times - I want this one camera to be disabled..
