Blue Iris + Deepstack + GPU
Hans007
Nov 21, 2016
68
16
Hi All. i read somewhere that it was recommended to have a GPU installed and use that together with Blue Iris and/or Deepstack, I therefor bought a used (cheap) Nvida Quadro P620, to get better performance.
But sadly it looks worse then before the GPU installed. AI no takes 3649ms where it before was around 1800ms
CPU I5-950 3ghz
RAM 16GB
GPU Nvidia Quadro P620
OS Win10 Pro
I followed Deepstack guide on Windows with GPU and have selected Nvidia NVDEC in Blue Iris. am i missing thing ? or is it just the GPU that is "no-go"
CPU I5-950 3ghz
RAM 16GB
OS Win10 Pro
Do you have CUDA installed, to check open a command prompt and execute "nvidia-smi" and post the results.
@MikeLud1,
So just did some more testing, sadly no big of a change. im still getting around 1800-2500ms, any ideas or troubleshooting guide that perhaps can cast some light on why im getting so high of number when using a GPU..
@MikeLud1,
Which version of deepstack are you using, it should be DeepStack 2022.01.1
did a little more analysis, and what I can see is that in the daytime hours it takes the AI approx 2500ms to identify an object, but it cancels the alert in less then 200ms and at the evening/night hours the AI takes less then 800ms.
and im getting almost the same values on all 6 cameras..
If you are on DeepStack 2022.01.1 it should not break it, older versions of DeepStack it will break it.
Yeah, I'm not on the new version. I'll wait until there's better integration between BI and CPAI and then make the move.
