Hey guys, I have no doubt I've misconfigured something that is causing this, but whenever I try to view clips in the mobile app on my iPhone Xs, it will sometimes load the first one or two ok, but then it'll hang in the app/webUI and Blue Iris will crash about 10 seconds later.
This also happens when trying to view clips using UI3 web interface.
I'm running BI in a Win10 VM with 8 cores assigned to it (it averages around 50% CPU usage), and it has 12GB of RAM available, and typically uses about 3-4GB. So I don't believe it's a case of it running out of resources.
The files are stored on a RAID array local to the VM. When I tested data transfer speeds, I was getting sustained transfers around 200MB/s, so I don't believe it's a throughput/bandwidth issue.
The array has 8TB free, and BI has 3TB allocated and is currently only using around 20GB (I deleted all clips and rebuilt the database to try to troubleshoot this). So I don't believe it's a running out of space issue.
Does anyone have any ideas of what I should try next to continue troubleshooting the issue?
Thanks!
Thanks!
