I'm sure many parts of this question have been answered across many posts but I'm trying to get an answer all in one place.
I am planning a new Blue Iris system which will replace a Swann NVR. I can access the 7 surviving Swann cameras on RTSP and I plan 3-4 new IP cameras. I have available a solid Dell PC with a XEON 1280-V3 CPU, so no QuickSync. I can put in a GTX1050 (extra power consumption) or an older Quadro card (FX1700 or similar, less power consumption).
My questions:
- I plan to do almost all viewing from other PC's via the web interface.
- Would Quicksync (if I had it) on the server make a difference to playback performance via the web interface?
- Does the GTX1050 on the server make a similar difference to playback performance?
- This post (under Encoder Preset) Optimizing Blue Iris's CPU Usage suggests that the CPU does decoding for remote viewing. Does QuickSync or a GTX1050 provide a performance advantage here?
- If I changed the CPU to have QuickSync would I need a monitor (or monitor simulator) plugged in for correct operation?
- Does QuickSync or a GTX1050 benefit in Direct-to-Disk recording?
My questions:
