I have been running Blue Iris for years. Recently two of my Cameras started changing configurations spontaneously.
The cameras have an assigned IP address of
10.0.1.213 (TH_Pointing SE)
And
10.0.1.215 (THNE)
They are configured with that address in Blue IRIS and the cameras are visible for a little while. That is until they SPONTANEOUSLY change their Configuration in Blue IRIS and go offline.
The two cameras keep going offline with Blue Iris because they keep SPONTANEOUSLY reconfiguring themselves to the IP address of a HUE Bridge. (See log below where it shows (Changed to IP 10.0.1.9).
I did not make this change. It simply happened. Now that I have changed the Bridge to a 10.0.1.230 Address, the cameras are spontaneously changing to that address. Or they will spontaneously change to the same IP address between them. Either the 213 will change to 215 or, after I manually fix it, the 215 will change to 213. Some times the change lasts for hours, sometimes minutes. (See log below)
Why would these two cameras keep changing their IP address configuration in Blue IRIS without human intervention?
The IP Address of the cameras do not change, only the Blue IRIS camera IP Address config changes. And it changes without human intervention.
Any ideas why this might be happening?
And
10.0.1.215 (THNE)
