Hi all -
Maybe this isn't a problem, but I'm setting up my first camera in Blue Iris (demo version), and I notice that my switch memory usage is at 70% (see screenshot). This seems high since there are only 3 ports being used: one for the camera (Dahua 4231), one for computer, and one for the router. The switch is a Zyxel GS1900-8HP, and it is consumption mode.
If it's an issue, I'm wondering if it has anything to do with my camera/BI settings. BI is on a Win10 Dell Inspiron 3650, i5-6400, 8 GB RAM, 256G SSD with BI and OS, and 3TB WD Purple. BI isn't burdening the computer much: CPU is ~10%, 200MB Ram. I've followed the advice here: H.264 acceleration has been enabled in BI, clip database on SSD, new folder on purple drive.
I've set the max rate of camera to 12.5 fps (see screenshot), and it is actually recording at 12 fps and ~330 kb/S. The Dahua camera is set to H.264H, smart codec off, and I changed the main stream to 12fps/CBR/2500kb/s (see screenshot). Also, changed the substream to 12fps and left bitrate alone (unsure if substream is relevant).
So (1) is there any issue with 70% switch memory usage, and (2) somewhat unrelated, was my choice of 2500 kb/s bitrate proper for 12.5 fps?
Thanks!
Thanks!
