T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Sep 7, 2018 #1 on iOS using the newest blue iris app the traffic signal does not work, you can’t turn it on or off. It looks like it is grayed out. On my desktop it works as it should. Any suggestions?
fenderman Staff member Mar 9, 2014 36,891 21,407 Sep 7, 2018 #2 Tazz 316 said: on iOS using the newest blue iris app the traffic signal does not work, you can’t turn it on or off. It looks like it is grayed out. On my desktop it works as it should. Any suggestions? Click to expand... the user needs admin privileges.
T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Sep 8, 2018 #3 fenderman said: the user needs admin privileges. Click to expand... That was it! Now is there anyway to unmask the user password? If not guess i will have to make a new one.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,136 Alabama Sep 8, 2018 #4 Tazz 316 said: That was it! Now is there anyway to unmask the user password? If not guess i will have to make a new one. Click to expand... Not to my knowledge....so now would be your chance to record that new password in a safe place.
T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Sep 8, 2018 #5 TonyR said: Not to my knowledge....so now would be your chance to record that new password in a safe place. Click to expand... I know it's been years since i made the first one, there used to be a way to find them in the registry for the ip cams
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,136 Alabama Sep 8, 2018 #6 Tazz 316 said: I know it's been years since i made the first one, there used to be a way to find them in the registry for the ip cams Click to expand... Try ==>> this. Reactions: gwminor48
