- Dec 20, 2016
- 277
- 41
Hello ya'll!
So I went with Verizon's home internet 5G for my houseboat. 90% of the time its at the dock. Only a couple times a year do I take it out on the lake.
the problem I'm running into is that it keeps changing it WAN IP address. Since I'm about 2.5 hour drive away, I'm not sure if it is doing it because of a power failure or its just changing on its own.
It was $35 per month for 3 years. I'm running it in passthru mode to my ASUS RT-AX82U (AX5400) Dual Band WiFi 6 router. Verizon has about 3 or 4 slightly different models of their big White Cube (Internet Gateway-Titan) for 5G internet. The version I have is the ARC-XCI55AX, Verizon Internet Gateway (ARC-XCI55AX) - Support Overview. I can use Teamviewer to login remotely to the server on the boat. But I have to go into Webserver, hit refresh and get the new WAN IP adress to see the cameras.
Any suggestions?
Any suggestions?
