I've put together a Hikvision system of 5 IP cameras and a Hikvision NVR with 2x3TB WD Purple drives. The network is all set up using POE switches in 2 locations and the Hikvision software sees all cameras.
I then came across Blue Iris and after reading reviews I bought a licence. I am using a SandyBridge based i7 pc at the moment and as expected the cpu load is at 100% so Ive tried direct to disk recording which works fine in reducing load.
Of course ATM I'm not recording to the NVR only to the pc hdd so the NVR is somewhat redundant! My question is, can I use the nvr's recording properties while using BI on the pc and access all the BI functions?
My other options would be:
Abandon BI and forget using the pc, this means using Hikvision software which I don't particularly like,or:
Abandon the NVR and sell it while spending money on building a more powerful i7 pc
You've probably gathered I'm a complete newbie at cctv but thanks for looking anyway.
