S Sparkey Getting comfortable Apr 3, 2015 329 272 The United States of Gawgia Jul 7, 2023 #1 What's the best make and model to set this cam up in Blue Iris? Right now it's set up as - It would be nice if I could access mechanical zoom from BI. TIA
wittaj IPCT Contributor Apr 28, 2019 32,912 62,983 USA Jul 7, 2023 #2 It is best to hit find/inspect and let BI pick the best. Some cams in the PTZ tab try the different Dahua protocols
S Sparkey Getting comfortable Apr 3, 2015 329 272 The United States of Gawgia Jul 7, 2023 #3 wittaj said: It is best to hit find/inspect and let BI pick the best. Some cams in the PTZ tab try the different Dahua protocols Click to expand... Blue Iris picked the above cam. I'll try others and see what I can come up with. It sure would be nice if BI listed this exact cam.
S Sparkey Getting comfortable Apr 3, 2015 329 272 The United States of Gawgia Jul 7, 2023 #4 Just discovered the mechanical zoom controls. I'm a happy camper now.
