- Apr 15, 2018
- 2
- 0
I just updated my CodeProject AI version from 2.5.1 to 2.6.2 (big mistake, it always takes forever to get the new version going). This time though I can't get it back working. Before it was a dance of un-install CPAI, delete Program Files and Program Data Folders, un-check use AI in Blue Iris and then re-install everything reboot a few times and it usually starts working again. This time it doesn't even seem like anything is getting to CPAI, there is nothing in the CPAI logs when a motion event is triggered in Blue Iris. I dragged the .dat file into the AI tab in Blue Iris and see all sorts of errors I don't understand. I have un-installed re-installed like half a dozen times with no luck. I have attached a bunch of screenshots and haven't changed anything from when it was working with 2.5.1. Any help would be appreciated. Thanks!
