Blue Iris and CodeProject.AI ALPR
I've been out of updates for a minute..CPAI is no longer actively developed? Is there a new alternative, or just sticking with the latest release?
Thank you
Thank you
Are you having issues with 2.9.5? I'm not, so I'm sticking with that version.
Would I like to see active updates? Yes, but I'm content with a working system, for now.
Reactions: EvanVanVan
Lol, no I'm on 2.6.5 and happy :] but was looking to update and just wanted to confirm CPAI 2.9.5 would still be the best/recommended version before updating.
Is there a project on the horizon regardless? What happened to CPAI? it was so actively updated for a while there.
I'd read through the following thread and see if anything is relevant to you. In particular, since CPAI moved off of the CodeProject servers, some links for updates in 2.6.5 won't work. But if it is working for you, consider "if it ain't broke..."
Brand new docker in new Debian 12 install
ran this comment
sudo docker run --name CodeProject.AI -d -p 32168:32168 \
--mount type=bind,source=/etc/codeproject/ai,target=/etc/codeproject/ai \
--mount type=bind,source=/opt/codeproject/ai,target=/app/modules \
codeproject/ai-server
PaddelPaddle not installed for License Plate
Help please? Search came up with dead links and internet archiver didn't have any backups. :(
Paddlepaddle 2.6.0 is no longer available but I was able to backup my working codeproject.ai container in docker in Debian then restore that container to a different computer.
Backup Docker Image
docker commit codeproject-ai codeproject.ai:backup
docker save -o cpai_image_backup.tar codeproject.ai:backup
Backup Docker Data/folders
tar czvf cpai_data_etc_backup.tar.gz -C /etc codeproject/ai
tar czvf cpai_data_modules_backup.tar.gz -C /opt codeproject ai
SCP to copy and paste files from old computer to new computer, change file permission if you need
sudo chmod 666
Load image onto the new docker
docker load -i cpai_image_backup.tar
Create directories Restore data/folders
sudo mkdir -p /etc/codeproject/ai
sudo mkdir -p /opt/codeproject/ai
tar xzvf cpai_data_etc_backup.tar.gz -C /etc
tar xzvf cpai_data_modules_backup.tar.gz -C /opt
Run container
docker run -d \
--name codeproject-ai \
-p 32168:32168 \
--restart unless-stopped \
Reactions: PeteJ
