hi everyone.. i'm a total noob when it comes to setting this up. i thought it would be pretty straight forward, but guess not.
here is what i have:
Blue Iris - release 4.1.0.0 x64
Asus AC1900 router using internal DDNS function from asus.com
8910W foscam
* also the PC i'm running the blueiris on is connected to my router via WiFi
from blue iris, i was able to add my foscam to it and be able to view from it.
then i've tried to enable the port forwarding in the router and used Port Range 90:99 with both TCP UDP. yet when i try to check my IP from canyouseeme.org, it says the ports within that range are closed.
what gives? do i need to add the computer's IP that's running the blue iris manually into the router's firewall for IV6 inbound?
please help... thanks!
8910W foscam
