We're getting tired of our sluggish "high end" $4,000 Hikvision NVR and took the first step today buying the Blue Iris 5 software that was on sale here at IPcamtalk to see if a PC with BI will work better. Does anyone know if BI will dewarp fisheye cams? We have some of the Hikvision 12MP fisheye cams. While the cams can be programmed to send dewarp streams, the resolution is significantly decreased with that option, so we record in the full resolution warped mode. A bit annoying that the Hikvision phone app dewarps but local viewing with NVR and web viewing does not dewarp.
Also, and recommendations on PC hardware? Our NVR is supposed to handle 64 cams. We have 35 cams with most being 4MP and running at 10 FPS, with 10 6TB drives. NVR seems overtaxed. We may add 5 more cams for total of 40.
