Blue Iris 3.58.00 - July 12, 2014 --BIG NEWS AUDIO TALK ADDED FOR HIKVISION
fenderman
Staff member
Mar 9, 2014
36,891
21,408
I tested this on my 2432 cube via the pc application and it works. It does not work via the android app yet...probably after the next update...EDIT: It does work via android app, you just have to unclick the headphones (listen) before hitting the mic...it sounds great!
Hm i have it on g711ulaw codec. The microphone works great, I can hear the pretty clear audio input from the camera. Its the built-in speaker of the camera and audio output that doesn't sound so good no matter what, just enabling it on pc or on phone turns it on and a ringing noise comes out of the camera.
Thanks Fender I'll try out some stuff, my version is 5.1.2 ...maybe if i can find the older one i will downgrade it.
