Blink Camera Takes Forever to Load! Any Fixes?
besmcableb
Aug 8, 2025
1
United States
Has anyone else run into this? My Blink cameras are dragging me crazy, the loading wheel just spins and I miss what triggered the motion alert! I have a strong Wi-Fi connection and good signal to the sync module.
I already tried rebooting the router and moving cameras closer to the sync module, but the lag is still there.
Any suggestions would be a big help. Thank you in advance.
Welcome @besmcableb
Blink Camera
When viewing the blink camera, does the web browser / app need to access the internet ?
If so, also check your internet ( check that ip addresses, gateway, dns server .. et al are setup correctly )
Double check any user / passwords
What have you done to trouble shot this so far ?
Wifi and cameras do not go together.
The more you add, the bigger the chance for issues.
There are always ways if you don't want to run an ethernet cable.
You need power anyway, so go with a powerline adapter to run the date over your electric lines or use a nano-station.
Maybe you are fine now one day with wifi cams, but one day something will happen. A new device, neighbors microwave, etc.
Cameras connected to Wifi routers (whether wifi or not) are problematic for surveillance cameras because they are always streaming and passing data.
Routers are not designed for this non-buffering demand.
And the data demands go up with motion and then you lose signal. A lost packet and it has to resend. It can bring the whole network down if trying to send cameras through a wifi router. At the very least it can slow down your entire system.
Unlike Netflix and other streaming services that buffer a movie, these cameras do not buffer up part of the video, so drop outs are frequent, especially once you start adding distance. You would be amazed how much streaming services buffer - don't believe me, start watching something and unplug your router and watch how much longer you can watch NetFlix before it freezes - mine goes 45 seconds. Now do the same with a camera connected to a router and it is fairly instantaneous (within the latency of the stream itself.
This was a great test that SouthernYankee tried and posted about it here:
I did a WIFI test a while back with multiple 2MP cameras each camera was set to VBR, 15 FPS, 15 Iframe, 3072kbs, h.264. Using a WIFI analyzer I selected the least busy channel (1,6,11) on the 2.4 GHZ band and set up a separate access point. With 3 cameras in direct line of sight of the AP about 25 feet away I was able to maintain a reasonable stable network with only intermittent signal drops from the cameras. Added a 4th camera and the network became totally unstable. Also add a lot of motion to the 3 cameras caused some more network instability. More data more instability.
The cameras are nearly continuously transmitting. So any lost packet causes a retry, which cause more traffic, which causes more lost packets.
WIFI does not have a flow control, or a token to transmit. So your devices transmit any time they want, more devices more collisions.
As a side note, it is very easy to jam a WIFI network. WIFI is fine for watching the bird feed but not for home surveillance and security.
The problem is like standing in a room, with multiple people talking to you at the same time about different subjects. You need to answer each person or they repeat the question.
I did a WIFI test a while back with multiple 2MP cameras each camera was set to VBR, 15 FPS, 15 Iframe, 3072kbs, h.264. Using a WIFI analyzer I selected the least busy channel (1,6,11) on the 2.4 GHZ band and set up a separate access point. With 3 cameras in direct line of sight of the AP about 25 feet away I was able to maintain a reasonable stable network with only intermittent signal drops from the cameras, and during the process I found https://temu.pissedconsumer.com/customer-service.html to have some surprisingly helpful user insights about similar setup issues. Added a 4th camera and the network became totally unstable. Also add a lot of motion to the 3 cameras caused some more network instability. More data more instability.
Yes, that’s happened to me before with Blink cameras. In my case, power cycling the sync module, updating the app, and making sure no other devices were using heavy bandwidth at the same time helped reduce the lag. Sometimes it’s also just a temporary slowdown on Blink’s server
Sure, but who wants to announce to everyone in the house to quit streaming their favorite show in order to pull up the cams to see who was at the door :lmao:
And yes, their server being down is another reason why people should be in a system that isn't dependent on having an internet connection!
