Regarding BI4.latest,
In order to use Object "Zone Crossing", I assume I need to enable "Use zones and hot spot"? Is this correct?
I'm finding that if I do enable Zone Crossing, I'm getting a mixture of Zone Crossing and normal Motion triggering the camera.
Should I tick "Use Zones and Hot Spot", define the Zones, and then uncheck it? Or does Object Detection override Motion? Or will Zone & Motion always work together.
Im just confused.
Im just confused.
