Had to replace the work PC and couldn't locate our license for BI4, so purchased and installed 5 using imported settings from 4 (Win 10 machine).
I'm doing all of my recording to a hardwired NAS in another building. This is mapped as the Z: drive. If I set the recording folder as z:\BlueIris. it appears that everything is working, except that if you attempt to play a clip it returns an error that the selected clip cant be found (can get exact syntax if it matters, but I don't think its relevant), and there are no recordings in the Z:\BlueIris folder.
IF, however, I point to the same location as \\diskstation\nas\BlueIris, then quit and restart the program, it will record there as expected. Unfortunately a reboot takes us back to where we were, with no actual recordings made, even though the drive/folder is reachable via Windows Explorer.
Screenshot of the Clips and Archiving settings, notice in the right panel all of the zero second clips.
Hope this makes sense. Where to go from here?
