B .bernhard n3wb Jan 27, 2015 3 1 Jul 25, 2019 #1 Would like to have as it was in BI4; any help is appreciated! thx, bernhard
TL1096r IPCT Contributor Jan 28, 2017 1,211 471 Jul 25, 2019 #2 double click the clip pane. Reactions: BadBlake and Mike
B .bernhard n3wb Jan 27, 2015 3 1 Jul 25, 2019 #3 TL1096r said: double click the clip pane. Click to expand... THANKS! (simple enough) Reactions: Mike
DouglasteR Young grasshopper Nov 15, 2015 50 14 Jul 14, 2022 #4 Goddamit, here i searched for the same thing for the 10th time ! ARGH
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,140 Alabama Jul 14, 2022 #5 DouglasteR said: Goddamit, here i searched for the same thing for the 10th time ! ARGH Click to expand... TEN times? Try sticking a Post-it note on your BI monitor with "double click the clip pane" on it. Reactions: TL1096r, looney2ns and sebastiantombs
DouglasteR Young grasshopper Nov 15, 2015 50 14 Jul 14, 2022 #6 TonyR said: TEN times? Try sticking a Post-it note on your BI monitor with "double click the clip pane" on it. Click to expand... Everytime i install BI somewhere i end "how the F i switch the clip column to the right again?!" And then i end here again Reactions: looney2ns, TonyR and sebastiantombs
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,140 Alabama Jul 14, 2022 #7 DouglasteR said: Everytime i install BI somewhere i end "how the F i switch the clip column to the right again?!" And then i end here again Click to expand... You know many tattoo parlors have lowered their prices considerably because of COVID, so........ Reactions: looney2ns, sebastiantombs and DouglasteR
