I use a Dahua DH-SD1A404XB-GNR camera with Blue Iris 4. Working 90% at the moment, the PTZ controles are not working but i will come to that in a different topic. Less important for now.
What is more important is getting my pushsafer to work.
When i look at the examples:
www.pushsafer.com
I see screenshots, that is the way i thought Pushsafer would work with screenshots. I have a pushsafer account, so i get the message at my phone now but no screenshot. How do i insert a screenshot? And i looks like i need to have the pushsafer app logged in at all time. Is that true? Doesn't the message reach my phone without the logged in app? Only getting a message "Someone at the door" doesn't really do it for me
I wouldn't mind using the push to the BI app but it takes about two minutes to reach my phone. Which is not acceptable.
Is there a way to make the BI motion sensor not respond to the exterior lightning (which is on a simple motion detector)? At the moment i get a push message when somebody is at the door (which is fine). But i also get one about 3 minutes later when the exterior lightning turns off (of course this is only a problem at night). I unchecked "Object Detection" and selected "Use Zones and hot spot". This was necessary to make sure the camera doesn't respond to people walking in front of the house. I already drew the exterior lightning outside of the motion zone.
What do the options under "Highlight" mean? Or better question, which option should i use in this situation?
(Do not highlight motion, Highlight motion, Show object rectangles and Highlight and rectangles)
EDIT: The push to BI app works fines when i change the WAN address to my local LAN address. But this is not reachable from outside the house, so i will have to setup NGINX. This is a better option than Stunnel, right?
Example Blue Iris - Pushsafer - send push notifications easy and safe
Send push notifications easy and safe to ios, iphone, ipad, android, windows, devices
