make sure combine and cut is checked and that cut clip when triggered is unchecked in the record tab. This is the default, you must have changed it.BI creates a new clip for every time motion occurs on camera A. How do you set it for one file?
I end up with 20 clips of motion looking to have it all in one file.
that is correct, but remember those settings are profile specific. Also uncheck show jpeg on timelineIs this not right?
are you using more than one profile?Well that is the settings I was already using and getting multiple clips from the same camera.
Is there another setting somewhere?
Are you certain you're looking at clips versus alertsNever used the profiles only one i use is "Active"
In the clips list on the right hand side i will get multiple clips from the same camera, i get the slider you have pictured but in order to see the next clip from the same cam i have to go back into the clips list and select it.
I'm sure it is something simple.![]()
Delete the camera and add it backYes clips have a play button alerts is a triangle.
