There is a thread where I point to another codec pack...I have installed K-Lite Coldec pack 5.8.3 installed yet BI will not play the MP4 it records. Any suggestions?
searchCan you point me to the thread? I have done searches on this forum.
Also just so you know both Windows Media Player and Realplayer on my desktop can play the MP4s that BI creates.
why in the world do you need thumbnails? that is what blue iris is for...no need to viewI dont want to have to use the BI UI to find files. It is not very good at showing lots of files.
its excellent at showing lots of files...that is what the timeline and clips view is for...completely silly to look through video in folders makes no sense...
what would be the point of that...it will tell you nothing...with the timeline you can scrub it to quickly review the video or by using the clip view you can select the date and scroll through them...I can look at 120-200 thumbnails in a single window with MP4s. How can I do that with BI and bvr's?
Are you not using it for surveillance? This is not making sense...regardless, if you want to do things backwards and at the same time limit yourself to not being able to view an event until the files closes after recording, then search for the codec...I do not want to look at them by date
that is not the link...I linked to a specific codec that worked for someone with the issue...I had installed a codec earlier. I found a link you posted "Third Party Software - Blue Iris" and reinstalled the codec. I think it was the same I already had., It did not help. I will contact BI and see what codec they recommend. Thanks
search my threads or the blue iris section for "codec"
