I have the latest BI download (as of Sep 21, 2014) running on a Windows Home Server with 3 cameras installed (Airsight, Cisco, and Sricam).
All cameras are working. The Sricam is configured in BI as a FOSCAM MPEG because the Sricam AP005 choice was troublesome.
Everything was working until my Apple Extreme WiFi router developed a problem causing WiFi disconnects and I performed a factory reset to resolve that issue. The router is fine now - and I set it back up with the same options (NAT table was a test of memory).
Now, when using the url access to BI remotely, I can attach and view the live camera images. But when I select a stored "clip", BI says "Connecting..." in the middle of the image area and never moves beyond that. I can recover from that condition by selecting a live view any of the cameras.
When home on my LAN, I can view the clips without this problem. Obviously I've got something configured wrong. It may well be in the router setup - but nothing appears to be having any problem except BI and playing a clip.
I am using port 1050 to forward to my WHS Blue Iris url as 10.0.1.240:1050. This works fine both at home (on the LAN) and from remote access for live camera viewing. But the inability to play the stored clips from a remote access is perplexing. I have confirmed the same remote access problem on three other computers at work.
Should I switch the port number to something more standard?
Any ideas on where to start troubleshooting this situation?
Thanks in advance for any suggestions.
