Hi guys,
Trying to figure that out with no success:
I'm integrating BI with Facebox. facebox can get and image ising json post request (quoting from their info:
URL via JSON payload
If you submit a URL, Facebox will download that file and use it as though you posted it.
POST /facebox/check
url: "{url}"
I'm unable to figure out the syntax to use. If I got it right I need to send Facebox a url in which it will download the image to parse.
tried a couple of options but none of them worked.
Any one had some experience with it?
Any help will be appreciated
Gil
POST /facebox/check
url: "{url}"
- url - (string) The absolute URL of the file to download
- Set the Content-Type header to "application/json; charset=utf-8"
Gil
